Engine Cooling problem
1998 Pontiac Transport 6 cyl Front Wheel Drive Automatic 145 K miles
My vehicule is switching the coolant light on and off the coolant is full and doesn´t leak in the garage only I take it to the mechanic who scan it and it was an error in the tps and yes sometimes after a while the van seems to be over 2500 rpm those it has anything to do with the increase in the temp level, someone told me that I need to check also some wiring connectors that affect the fuel pump assembly, abs brakes and traction located in the proximity of the middle row, driver side seat, do you know anything about these conectors, cause I´m going to remove the carpet to see if there is any wrong with them
Thanks
Thanks
Oct 10, 2008 at 10:41 PM
