Where is the crankshaft sensor located on the Pontiac Sunbird with a 3.1 engine?
Wednesday, February 6th, 2013 AT 8:26 PM
MECHANIC
The crankshaft sensor is located on the right side of engine. Here is a guide to help walk you through the steps and a diagram below to show you the location.
Image (Click to make bigger)
SPONSORED LINKS
Wednesday, February 6th, 2013 AT 8:37 PM
WUTSUPY
MEMBER
1990 PONTIAC SUNBIRD
4 CYL
FWD
AUTOMATIC
90,000 MILES
Where is the crank position sensor on a 1990 Pontiac sunbird with a 2.0 motor and it has a distributor. I was told it was under the timing belt cover. Please help
Wednesday, January 16th, 2019 AT 7:22 PM
(Merged)
MMPRINCE4000
MECHANIC
I checked my parts book and it does not show a crank sensor for the car.
(Merged)
WUTSUPY
MEMBER
Hmm mine shows one for the 1992 with the same motor so I was double checking
(Merged)
WUTSUPY
MEMBER
Do you know what triggers the fuel injector to inject gas, that is my real problem
SPONSORED LINKS
(Merged)
VERN1939
MEMBER
I have same problem, but to much gas
New throttle body fuel sensor no change to much gas
Injector seems to be ok but no pulse toit.
Vern1939
(Merged)
WUTSUPY
MEMBER
Ok I was told to check the ignition module, how do I pull it out, and more importantly, how do I test it?.A few minutes latter, I just pulled it out, on the side with 3 prongs I get power to 2 of the 3 prongs, the one I dont get power to is labled B, is this my problem, and if itisnt I need to know how to test the module, with ohms? Or?
(Merged)
ALMW
MEMBER
1994 PONTIAC SUNBIRD
4 CYL
FWD
AUTOMATIC
94,000 MILES
I need to know what is a crank sensor and why my car wouldn't run without it?
(Merged)
BLUELIGHTNIN6
MECHANIC
A crank sensor is a component used in an internal combustion engine to monitor the position or rotational speed of the crankshaft. This information is used by engine management systems to control ignition system timing and other engine parameters. Crank sensors in engines usually consist of magnets and an inductive coil, or they may be based on magnetically triggered Hall effect semiconductor devices. Common mounting locations include the main crank pulley, the flywheel, and occasionally on the crankshaft itself. This sensor is the most important sensor in modern day engines. When it fails, there is a small chance the engine will start (engine will likely cut out after a few minutes of driving) but it mostly will not start
(Merged)
ALMW
MEMBER
Thanks you answer explained a lot. I had never heard of the crank sensor before.
