Hi, I have a 92 Sunbird 3.1L. Had a no start issue.Found out it had a bad module; replaced the module. Car ran for 15 minutes or so then shut off. Currently the car will not run, but will surge between 1500-2500 rpm (for two minutes)then shuts down. Crank sensor, ignition module and ecm have all been replace with no luck.
Mar 9, 2010 at 7:10 PM
