I realize, after doing a lot of unnessary work, that I have not found the turn signal flasher unit. Does anyone know where the turn flasher unit is located? It is not near the fuse box (convenience center), I thought the relay unit by the hazard flasher unit was the turn flasher but it was not. I have pulled the fuse center down and checked behind it, not there. Nor is it by the steering column like the manual states. I have pulled the instrument panel out and it is not behind it. It has to be somewhere up around the instrument panel as when it was working I could clearly here the clicking when signaling. I am looking for a round 2 prong unit right?
Dec 9, 2009 at 7:59 PM
