2001 Pontiac Montana starting
2001 PONTIAC MONTANA
101,000 MILES • V8 • 2WD • AUTOMATIC
WYNKOW
Montana periodically ( cooler weather) delayed start when you turn ignition key car does nothing untill you release the key back and then starter engages and starts. SOmetimes delayed up to 5 seconds. I checked tightness of batt cables, batt is 3 yrs old , possible flat spot in igntion switch ? bad starter coil ? bad starter motor ?
Nov 23, 2009 at 8:56 PM
