2000 Pontiac Montana 2000 Pontiac Montana won't start
2000 PONTIAC MONTANA
137,500 MILES • 6 CYL • FWD • AUTOMATIC
HANNIKENRACING
It ran perfect but the radiator and the front oil sending unit leaked so I unhooked the positive battery terminal and changed the sensor and the radiator only to find that it wouldn't turn over at all I checked the starter at the auto parts store and my ignition wires coming down do not have any power in them. I was unable to find a fuse and the relay is good and if you have someone hold the key in the start postion and jump across the starter solenoid it will run just as it did before Any Ideas?
Feb 28, 2009 at 12:10 PM
