Car just stalls...
PONTIAC GRAND PRIX
MISTERWOOD88
I have a 1999 Pontiac Grand Prix GT V6 3.8Liter. Yesterday my gas tank was a little below so I go to put regular unleaded gas into it. I drove it home fine with no problems at all. After about an hour I leave my house and drive it about a mile down the street when the car just randomly turns off. In order for me to start it back, I had to hold down the gas pedal. Now today it won't even start and when it does I have to floor the gas pedal...there is a strong smell of gas and my car sounds like an old car when it does start up. What could possibly be the problem and how much does it cost to get fixed?
Oct 10, 2007 at 12:48 AM
  • CAR REPAIR CONTRIBUTOR
You need to check the fuel filter when it checks out. Check the fuel pressure, pressure in specs.
When it won't start disconnect a plug wire and ground it to the engine while cranking it over, Do you have spark-Got spark-next step is to look for fuel-crank engine and listen to the injector/s are they clicking and do you smell fuel in the throttle body. Do this and comeback
Oct 10, 2007 at 4:30 AM
MISTERWOOD88
Okay I do smell gas in the throttle body....what does this mean?
Oct 10, 2007 at 8:45 PM
[quote:4cfa7b851a="misterwood88"]Okay I do smell gas in the throttle body....what does this mean?[/quote:4cfa7b851a]
Now check the actual pressure with gauge-could be wrong pressure-pressure checks out-We'll do the valve and igntion timing -
Oct 10, 2007 at 9:14 PM
MISTERWOOD88
Now my car will not start at all....it just backfires from the muffler and from the front of the engine it sounds like its gasping for air. What's wrong now....IT GOT WORSE AAAHHH!!!!
Oct 11, 2007 at 11:51 AM
Disconnect a spark plugwire and ground it to the engine while cranking engine over-Do you have spark?
When was it last tuned-up?
Oct 11, 2007 at 1:24 PM
TEKMASTER1954
If your smelling fuel, it could be that your fuel pressure regulator has gone bad and is dumping to much fuel causing a rich mixture. this would cause the conditions that you explained.
Oct 13, 2007 at 3:31 PM
