Horn will not stop blowing
MALCOLM J. MITCHELL
  • 2004 PONTIAC GRAND AM
  • 76,000 MILES
I have to pull the fuse to get the horn to stop. How do I fix it?
Saturday, April 21st, 2012 AT 8:56 PM
Could be the horn relay sticking or the horn button circuit is shorted out
Looks like fuse 43 is strictly for the horn, you could pull it, if that causes other things to not work, pull the horn relay
See the diagram below for fuse/relay locations and full wiring diagram
Saturday, April 21st, 2012 AT 9:05 PM
LASHAE67
2004 Pontiac Grand Am
My horn goes off at night and wont stop until you disconnect the battery. Is there a horn relay or a sensor that needs to be replaced?
Saturday, November 10th, 2018 AT 8:17 AM (Merged)
JDL
  • 16,098 POSTS
Hi, there should be a horn relay, underhood fuse box, unplugging the relay should kill the horn. I'd have all trouble-codes checked. Your theft system could set off the horn, problem with horn switch and wiring circuits?
GABY04
  • 8 POSTS
  • 2003 PONTIAC GRAND AM
Electrical problem
2003 Pontiac Grand Am 6 cyl Automatic
Hello, I am having a problem with the horn in my car. The brass ring that makes activates the horn is damaged and I rather not replace it because of the work involved. I heard some people have bypassed the steering column and have wired the horn to a push button, which I do not mind doing. I know what color the horn wire is, I just do not know the exact wire in the steering wheel column. There are 2 black wires in the steering column, I just dont know which of the 2 is the horn wire.
Saturday, November 10th, 2018 AT 8:18 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
The problem with dealing with the steering column is that there is always a chance that you could accidently deploy the airbag.
I would get a horn from an autoparts store and wire it in seperatly.
MILLERGENT
  • 2005 PONTIAC GRAND AM
Electrical problem
2005 Pontiac Grand Am 6 cyl Front Wheel Drive Automatic 36.000 miles
HORN WON'T STOP BLOWING
MMPRINCE4000
  • 8,548 POSTS
Pull horn connector to stop it, but it is either a stuck relay or horn button.
Quickly touch the horn relay, if it is warm/hot then most likely the relay.
