1999 Pontiac Grand Am
1999 PONTIAC GRAND AM
MOODSWINGS34
Engine Cooling problem
1999 Pontiac Grand Am 6 cyl
my car is a nightmare!engine runs about 210-then 280 and reservoir not holding fluids.Replaced thermostat,relay switches,and reservoir cap already about a week ago.Oil appears normal,put stop leak in it about a month ago.think I may have damaged it further,passes pressure test,when heat runs temp.is ok but heat comes and gos.do not see any visible leaks but it takes a gallon of water to get 5 miles to work and I have to pull over frequently.Do you think a coolant flush would help?maybe water pump?
Dec 10, 2009 at 7:04 AM
MMPRINCE4000
  • CAR REPAIR CONTRIBUTOR
  • 8,548 POSTS
Start with a compression test to rule out headgasket problem.
If OK, then perform a cooling system pressure test.
Could be a waterpump or many things, try the above first and post results.
Dec 10, 2009 at 9:03 AM
