spark plug replacement instructions please?
2005 PONTIAC GRAND AM
70,815 MILES • 4 CYL • FWD • AUTOMATIC
ROIXEJO78
where exactly on my car would they be & how do i change them? help!
Jan 17, 2010 at 4:03 PM
  • CAR REPAIR CONTRIBUTOR
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car. https://www.2carpros.com/articles/how-to-change-spark-plugs SPARK PLUG REPLACEMENT REMOVAL PROCEDURE *NOTE: This engine has aluminum cylinder heads. Do not remove the spark plugs from a hot engine, allow it to cool first. Removing the spark plugs from a hot engine may cause spark plug thread damage or cylinder head damage.
https://images.2carpros.com/forum/automotive_pictures/12900_sparkplug1_1.jpg
1.Remove the ignition coil housing. 2.Remove the spark plugs with a spark plug socket. IMPORTANT: Remove any water and debris from the spark plug holes before spark plug removal with compressed air. 3.Inspect the spark plugs. INSTALLATION PROCEDURE
https://images.2carpros.com/forum/automotive_pictures/12900_sparkplug2_1.jpg
1.Gap the spark plug, using round wire type spark plug gap gage. Adjust the spark plug gap to 1.14 mm (0.045 in) . 2.Install the spark plugs with a spark plug socket. IMPORTANT: DO NOT coat the spark plugs with anti seize compound. Over torquing could occur and damage to the cylinder head threads may result. NOTE: Refer to Fastener Notice in Service Precautions. Tighten the spark plugs to 20 N.m (15 lb ft) . 3.Install the ignition coil housing. USER NOTES: The procedure doesn't apply to grand Ams. Grand Ams have their plugs horizontally on the side banks of the engine. No need to touch coils.
Jan 17, 2010 at 4:54 PM
CARFREAK8184
  • 16 POSTS
Where are the spark plugs for the v6 grand am?
May 19, 2021 at 7:18 PM (Merged)
SATURNTECH9
  • 30,869 POSTS
REMOVAL PROCEDURE
1. Turn the ignition key OFF.
2. Remove foreign material from around the spark plug holes.
3. Remove the spark plug wire and using a spark plug socket remove the spark plug's.
1. Adjust the spark plug gap. Refer to Spark Plug Gap In General Information. Use a round wire type spark plug gap gauge. While gapping the plug be sure to keep the platinum pads aligned to ensure maximum plug life.
2. Install new plugs and tighten properly.
3. Reapply dielectric lubricant to the insulator boot.
Tighten
Tighten to 19 N.m (14 lb ft) .
BIGDADDYPUF
Easiest way to replace the 3 plugs on back side of motor
DRCRANKNWRENCH
  • 3,380 POSTS
You may have to remove some of the intake components/heat shield to get to the back plugs. You can get a spark plug tool that is a flexible spring that usually fits on a ratchet. It allows you to go around parts that are in the way of using a straight ratchet extension.
I am putting a diagram of the intake in this post so you can see what you would be dealing with if you remove it. I don't think you will have to go this far as you can remove part of the air intake and a heat shield and it would help to have the flex extension, and you should be able to get to the spark plugs.
Before you try to remove them, soak the spark plug in its recess with WD40 or even better is PB Blaster.
CATFISHER23
hello i was trying to locate were my spark plugs were at on my engine but i cant find them can u help.
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_spark_plugs_1.jpg
The plugs are located in the picture for the IDI system, if other, follow the plug wire.
