sunroof is not working correctly
2003 PONTIAC GRAND AM
156,000 MILES • 3.4L • V6 • FWD • AUTOMATIC
SKI2FISH
  • 8 POSTS
My sunroof is stuck in the vent position with the back open & one side higher than the other. When pressing the close position on the switch, nothing happens except for a click. When pressing the open position of the switch, the roof moves back about 1/2" on one side & stops. Pressing close again moves the one side of the roof that moved back forward the 1/2' then it stops. I've checked the fuse & it's fine. I referred to the Haynes repair manual, & it said to check the continuity on some of the terminals on the switch. Checking across the first 2 terminals on the right, there is no continuity as the book states. Checking across terminals 2 & 3, there is also no continuity, but the book says that there should be continuity. I also ran a jumper wire to ground as the book states but the roof did the same things as above. I do not want to take the motor out as I understand that it can be quite a lot of trouble to get the roof re-timed so that it works correctly. The book states that you should not take the motor out unless the roof is closed which it is not. Any suggestions??
Aug 20, 2015 at 7:26 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
Yep something has come apart or the motor is burned out here are diagrams BELOW that show you how to do the work and get the problem fixed.
Check out the diagrams (Below). Let us know what happens and please upload pictures or videos of the problem.
Cheers
Aug 21, 2015 at 8:05 AM
MGCAMARORS
  • 9 POSTS
I have a 2002 Grand am and sunroof is stuck in vent position the tilt up. It still rolls all the way open and shuts , but it will not shut completely its stuck in the vent position if yall have any advice i would appreciate it
Dec 5, 2019 at 11:18 AM (Merged)
MGCAMARORS
  • 9 POSTS
could someone tell me if the sunroof on my vehicle has a relay and where its located 2002 grand am 2door 2.2 automatic
GREENMAN007
here's the scoop...everything was ok with car..was cruisin sunroof open cus i smoke...when i closed it..all of a sudden its starts to glich..starts creepin open...attempted to close..but it decided to open all the way...wtf?? so any ideas cus i was quoted 350Can just to close it..n 60 bones to check the switch..how do i close it myself till i can afford it repaired? it looks gheto with cardboard in there..lol
May 19, 2021 at 7:24 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
can you hear the motor running when you press the switch? if not then motor may be bad and you will have to manually guide the roof panel down into place.
GREENMAN007
no...cannot hear anything..just the click of the switch...is it possible to close myself or do i hav to pay 350 to get it closed?? thnks for responding quickly...appreciated. i know the headliner has to come out..is it relativly simple to do??
BLUELIGHTNIN6
  • 16,542 POSTS
seems like the switch is faulty then. There are two little hydraulics at the front of your sunroof. One on the left and one on the right. They sit at about a 45 degree angle. Take something like a window scraper and push on the backside of the hydraulic. It will push in and you will feel your sunroof go down slightly. Do the same thing to the other side. Get out of your car and you should then be able to push the sunroof the rest of the way down from outside of the car. If it doesn't push down easy don't force it or you may damage
