How to replace the heater core
1995 PONTIAC GRAND AM
90,000 MILES
ANONYMOUS
how to access heater core for removal and replacement i
Jan 4, 2013 at 6:02 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
You got lucky on this one... the dash doesn't have to come out
Remove or Disconnect
1. Negative battery cable.
2. Drain cooling system. Refer to: See: Cooling System > Procedures
3. Raise vehicle.
4. Drain tube from heater case.
5. Heater hoses from heater core.
6. Lower vehicle.
7. Console (if equipped).
8. Right and left sound insulators.
9. Steering column opening filler.
10. Floor air outlet duct.
11. Heater core cover.
12. Heater core mounting clamps and remove heater core.
Install or Connect
1. Heater core and heater core mounting clamps.
2. Heater core cover.
3. Floor air outlet duct.
4. Right and left sound insulators.
5. Console.
6. Steering column opening filler.
7. Raise vehicle.
8. Heater hoses to heater core.
9. Drain tube to heater case.
10. Lower vehicle.
11. Negative battery.
12. Fill cooling system and check for leaks. Refer to: See: Cooling System > Procedures
See the diagrams below for component locations described above
Jan 4, 2013 at 6:03 PM
DOYLE4029
Heater problem
1995 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic
How to replace heater core
Dec 2, 2018 at 8:29 AM (Merged)
MMPRINCE4000
  • 8,548 POSTS
Use the car repair manual link in the thread or get a Haynes manual.
Some are easy to replace, some you have to remove a good portion of the dash.
GZSCORPIO
how to change heater core 1995 pontiac grand am se
v6
HEATER CORE
REMOVAL
Disconnect battery ground cable.
Raise and support vehicle.
Disconnect heater hoses from heater core assembly.
Remove drain tube.
Lower vehicle.
If equipped, remove console as follows:
Apply parking brake and block drive wheels.
Position transaxle shift lever in Neutral.
On models with automatic transaxle, remove clip retaining shift lever handle to lever, then remove shift lever handle.
On models with manual transaxle, turn shift lever handle counterclockwise to remove from lever.
On all models, carefully pry upward on outer edges of console trim plate.
Disconnect electrical connectors and ashtray lamp from console trim plate, then remove trim plate from console.
Remove console to mounting bracket attaching screws, then remove console.
Floor Air Duct Outlet
Heater core cover.
INSTALLATION
Heater core cover.
Console.
Raise vehicle.
Lower vehicle.
JASBOB77
need diagrams on how to replace heater core
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_897.jpg
FIG. 2
https://images.2carpros.com/forum/automotive_pictures/261618_Graphic_149.jpg
JIMZIM
whats the best way to replace a heater core in a 1996 Pontiac
GrandAm
BLUELIGHTNIN6
  • 16,542 POSTS
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_950.jpg
STEVEBE
Need detailed information for replacing a heater core on a 1996 Pontiac Grand Am GT
BMRFIXIT
  • 19,053 POSTS
Removal & Installation 1.Disconnect negative battery cable. Drain cooling system. Raise and support vehicle. Remove drain tube. Disconnect heater hoses from heater core. Lower vehicle. 2.Remove console (if equipped). Remove left and right sound insulators from below instrument panel. Remove floor outlet duct. Remove heater core cover and heater core. . To install, reverse removal procedure. Fill cooling system
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_123.jpg
MAMAGOOSE183
I need a diagram or detail instructions for the replacement of the heater core, are there any tabs that hold it in that might get broken in removal, have replaced heater cores in older cars,how much of the plastic under dash needs removed.
HEATER CORE
https://images.2carpros.com/forum/automotive_pictures/12900_heatercore1_3.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_heatercore2_3.jpg
REMOVAL 1.Disconnect battery ground cable. 2.Drain cooling system. 3.Raise and support vehicle. 4.Disconnect heater hoses from heater core assembly. 5.Remove drain tube. 6.Lower vehicle. 7.If equipped, remove console as follows: a.Apply parking brake and block drive wheels. b.Position transaxle shift lever in Neutral. c.On models with automatic transaxle, remove clip retaining shift lever handle to lever, then remove shift lever handle. d.On models with manual transaxle, turn shift lever handle counterclockwise to remove from lever. e.On all models, carefully pry upward on outer edges of console trim plate. f.Disconnect electrical connectors and ashtray lamp from console trim plate, then remove trim plate from console. g.Remove console to mounting bracket attaching screws, then remove console. 8.Right and left sound insulators. 9.Steering column opening filler. Floor Air Duct Outlet
https://images.2carpros.com/forum/automotive_pictures/12900_heatercore3_2.jpg
10.Floor air outlet duct. 11.Heater core cover. 12.Heater core mounting clamps and remove heater core. INSTALLATION 1.Heater core and heater core mounting clamps. 2.Heater core cover. 3.Floor air outlet duct. 4.Right and left sound insulators. 5.Console. 6.Steering column opening filler. 7.Raise vehicle. 8.Heater hoses to heater core. 9.Drain tube to heater case. 10.Lower vehicle. 11.Negative battery cable. 12.Fill cooling system and check for leaks.
