Thermostat location
2006 PONTIAC G6
103,000 MILES
ANONYMOUS
Where is the thermostat on a v6 engine?
Dec 14, 2012 at 2:15 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
There are two different locations depending on the engine size so I gave you both and a guide to help you see step by step how to do the job with diagrams for the location below.
Cheers
Dec 14, 2012 at 2:16 AM
TRANDO
Six cylinder front wheel drive automatic.
Where is the thermostat located on a GTP 3.9L engine?
Aug 2, 2018 at 5:28 PM (Merged)
Thermostat location see diagram below:
https://images.2carpros.com/forum/automotive_pictures/12900_tp_1.jpg
Aug 2, 2018 at 5:29 PM (Merged)
RAM47
Where is thermostat housing for 3.9l engine?
The thermostat is on the left side of the engine down low. Here is a guide to help you get it changed out and the location below:
Cheers
REVOKD69
Where do I find the thermostat on the 2.4L engine? I disconnected the upper radiator hose and it was not there. I read somewhere it's on the lower hose, but want to verify this before I go wasting any more time.
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_06_G6_thermostat_1.jpg
My information shows the above location for thermostat housing. If that is wrong, blame the database.
REVOKD69
Okay, I am blaming the database then I suppose, because that does not look like a diagram of my engine at all. The upper radiator hose connects the to the front of my engine, not the top rear like it shows there. Are you sure that is for the four cylinder? Thanks for trying, but any other ideas?
JDL
  • 16,098 POSTS
That is what MOD showed for the 2.4. I will keep looking. There are three G6s listed for that year. The GPT thermostat housing is shown below. I cannot guarantee the database is correct. I thought MOD was one of the better ones.
https://images.2carpros.com/forum/automotive_pictures/170934_gpt_thermostat_housing_1.jpg
REVOKD69
That one looks more like it. If this diagram is right it is actually connected to the lower hose which will be difficult to reach without pulling the radiator. I hope it is wrong again though, haha.
BENLOUD
Where is the thermostat in my car listed above with a 3.5 liter engine?
JDL
  • 16,098 POSTS
Yeah, it would not be the first time I was wrong, probably will not be the last. Good luck.
DOCFIXIT
  • 18,828 POSTS
This is it.
Drain the cooling system. Refer to draining and filling cooling system (LY7, LZ4, LZ9 Static Fill) draining and filling cooling system (GE 47716 fill) draining and filling cooling system (LE5 static fill) .
Remove the air cleaner outlet duct.
Reposition the radiator outlet hose clamp at the thermostat housing.
Remove the radiator outlet hose from the thermostat housing.
Remove the thermostat housing bolt/stud.
Remove the thermostat housing and gasket.
Remove the thermostat.
Clean the gasket surfaces.
JOANNALEBLANC
Need to change the thermostat and I'm not sure where it is located. Thanks so much for your help.
ORDIE
where is the thermostat located on a 2007 Pontiac G6 GT
BLUELIGHTNIN6
  • 16,542 POSTS
For the 3.5L engine it is located at the end of the radiator outlet hose at the engine end of hose. Drain the coolant, remove the air cleaner outlet duct, loosen the radiator outlet hose clamp at the thermostat housing then remove radiator outlet hose from housing. Thermostat is in the housing.
YOBOIIBLUE
Do I follow the top hose or the bottom hose on the radiator?
BLUELIGHTNIN6
  • 16,542 POSTS
Outlet should be top hose.
MARIAPATTERSON
Six cylinder two wheel drive automatic.
I need my thermostat replaced, but I do not know where it goes. Could you tell me where it is located?
BRIAN 1
  • 1,030 POSTS
what engine??? there all different,2.4,3.5,3.6,3.9??
