HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
G6
Exterior Light
Brake Light
Stay On
SPONSORED LINKS
Brake lights stay on?
MLWEESE
MEMBER
2007 PONTIAC G6
6 CYL
FWD
AUTOMATIC
45,000 MILES
The brake lights on my car are staying on all the time and shutting off when I actually brake. Ideas?
Monday, September 7th, 2009 AT 8:53 PM
BLUELIGHTNIN6
MECHANIC
You have a poor ground connection. Check the brake lamp switch wiring, below driver side dash mounted on brake pedal arm.
SPONSORED LINKS
Monday, September 7th, 2009 AT 9:17 PM
CKGAULDIN
MEMBER
1 POST
2006 PONTIAC G6
6 CYL
FWD
AUTOMATIC
73,000 MILES
The brake lights on my pontiac g6 won't go off. They are on continously? Every now and then they will go out when you press the brakes?
Sunday, October 18th, 2020 AT 10:52 AM (Merged)
MECHANIC
THere is a switch at the top of the brake pedal. Check to make sure it is not sticking or out of adjustment.
Let me know what you find.
Please
login
or
register
to post a reply.
Related Brake Light Stay On Content
High Mount Brake Lamp
How Do I Replace The High Mount Lamp On My Car? Its Located Inside The Car's Rear Window. Cannot Figure Out How To Take It Off.
Asked by
Roger Fernandez
1 ANSWER
6 IMAGES
2006
PONTIAC G6
SPONSORED LINKS
How to Use a Test Light
Headlight Dim or Dull
Turn Signals Blink Fast
Online car repair manuals
