1998 plymouth voyager
1998 PLYMOUTH VOYAGER
ALOVERCI
My 98 voyager minivan has been giving me several problems at one time. I was leaking antifreeze and had a cream backwash on my oil cap, I also has the il alarm going off; when the oil is full.. Went to mechanic and they replace waterpump, hoses, bypass hoseand timing belt. The check engine light is stil on, and the oil alarm started going off again. The oil is full. Could this be the oil pump?
Mar 26, 2006 at 12:50 PM
PEPPERMRJ
  • CAR REPAIR CONTRIBUTOR
  • 1,158 POSTS
Does the oil cap and dipstick look like a chocolate milk shake? If so you are mixing oil and coolant. Chances are good that you have a blown headgasket or cracked head. Have a compression check done to verify.
Good luck and let us know. :)
Mar 26, 2006 at 3:45 PM
