1996 Plymouth Voyager Premium Instrument Cluster
1996 PLYMOUTH VOYAGER
MR.RONE
Electrical problem
1996 Plymouth Voyager 6 cyl Two Wheel Drive Automatic
On the Instrument Cluster the Temperature, Tachometer, Speedometer, Fuel gauge are not moving and the voltage, seat belt reminder,low washer, odometer/trip odometer, transmission range indicator, door ajar light are not popping on. I switched the cluster fuse the fuse is fine. what else could be the problem, do you think it might be a relay?
Aug 30, 2009 at 3:10 AM
