Turn the ignition key, engine rotates but will not start. 96 Plymouth Grand Voyager SE V6 w/Auto Transmission. 156,000 miles. It was running good until now.
Here's the list of things that I checked so far:
Battery - Brand New
Air Filter: Good and Clean.
Spark Plug - Good
Sparks - Yes, I remove one of the spark plugs w/wire attached and asked my wife to start the engine - spark plug makes sparks as it cranks.
OBD II Scan: I bought a used Actron OBD II reader from ebay and scanned it. NO Error Message or Code. 0(Zero Error)
Timing Chain: I'm not sure. I have replaced it on 100,000 miles.
Fuel Pump: I put the ignition on and listened for the humm sound from the fuel tank... it makes humm sound.
Distributor: This one has rotor-less distributor. It makes sparks... I assume this is good sign, right?
What could be the problem?
I thank you advance for your help~!!!
-= Brian =-
Battery - Brand New
Spark Plug - Good
-= Brian =-
Aug 23, 2010 at 6:40 PM
