1995 Plymouth Acclaim fuel pump
1995 PLYMOUTH ACCLAIM
RETTELL36
Engine Mechanical problem
1995 Plymouth Acclaim 6 cyl Front Wheel Drive 146000 miles
I replaced fuel filter used starter fluid and it will start and run but only for a minute. I dont hear a humming sound when the key is on. I have heard that banging on the gas tank can open the brushes in the fuel pump is this true, and should i try this to see if it will run
Feb 15, 2009 at 7:42 PM
