1999 Mitsubishi Eclipse P0171 code is haunting me
KRYPTECLIPSE
  • 1999 MITSUBISHI ECLIPSE
  • 2.0L
  • 4 CYL
  • 80,000 MILES
I am getting this code. I have done everything the code says and the light is still on. The car now runs a whole lot better but I cannot erase the code. I have done everything from resetting the computer in many auto parts stores and at my mechanic. Code may erase but will come out in an hour or two. The mechanic does not what else to do. These are the things I have changed:
oil change and filter
egr
O2 sensors
PVC
PVC valve hoses
vacuum hoses
spark plugs and wires
fuel filter
fuel pressure regulator
put a fuel injector cleaner in the tank
fuel pump
air filter
coolant temperature sensor
idle control valve
intake air temperature sensor (IAT)
intake manifold gaskets
seafoam
brake booster hose
any help would be great
Thanks in advance
Friday, November 14th, 2014 AT 7:00 AM
  • 108,192 POSTS
Has anyone checked for a vacuum leak? Have you checked fuel pump pressure to make sure it isn't weak?
Friday, November 14th, 2014 AT 8:20 AM
HMAC300
  • 48,601 POSTS
Check your fuel pressure with a gauge if non turbo it should be 47-50 psi with key on engine off and if turbo should be 33psi @ idle. Also check for a vacuum leak use choke cleaner and spray around intake if rpm changes you found it.
Friday, November 14th, 2014 AT 8:21 AM
KRYPTECLIPSE
  • 45 POSTS
No leaks and pump is brand new and properly installed. Double checked that
Friday, November 14th, 2014 AT 8:31 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,904 POSTS
Read this for more info:
https://www.2carpros.com/articles/repair-lean-mixture-codes-p0171-or-p0174-on-some-manufacturers
Let us know what you find.
Best, Ken
Friday, November 14th, 2014 AT 8:46 AM
KRYPTECLIPSE
  • 45 POSTS
Did all that but still no luck
Friday, November 14th, 2014 AT 10:37 AM
HMAC300
  • 48,601 POSTS
Check connections at O2 sensor as well as ecm. I t may be a bad ecm unless your mechanic did a freeze frame and checked all the figures for being correct.
Friday, November 14th, 2014 AT 12:02 PM
KRYPTECLIPSE
  • 45 POSTS
How would you go about checking the ecm
Friday, November 14th, 2014 AT 2:28 PM
HMAC300
  • 48,601 POSTS
Check everything else first and then see if ecm is sending a signal out and return
Friday, November 14th, 2014 AT 2:57 PM
KRYPTECLIPSE
  • 45 POSTS
Sorry I haven't gotten back because I was on a business trip. The car runs great the only problem is the light. I was thinking could it be possible that the ecm may be stuck on that code.
Thursday, December 18th, 2014 AT 6:39 AM
HMAC300
  • 48,601 POSTS
If an ecm "gets stuck" then the problem is the ecm or a connection. If everything checks out to the ecm and the light still I s lit then its' got to be the ecm. The only thing I can think of her eis that fuel pressure should be48-51 w/o vacuum at idle unless this is a turbo which should be 42-45 w/o vacuum at idle. Unless it's a vacuum leak at intake etc. Try spraying choke cleaner around intake to see if idle changes. If it does I tmay be leaking vacuum. Other than that I cannot give any other suggestions.
Thursday, December 18th, 2014 AT 7:59 AM
KRYPTECLIPSE
  • 45 POSTS
Thanks for all your help
Thursday, December 18th, 2014 AT 8:10 AM
KRYPTECLIPSE
  • 45 POSTS
  • 2.0L
  • 4 CYL
I am getting this code. I have done everything the code says and the light is still on. The only thing I noticed is that it has a very rough idle when in the stop lights. The car sounds like it is sputtering and when I get out the car has a smell of gas from the exhaust. Another thing is that it acts like it wants to die out sometimes. These are the things I have changed:
O2 sensors
PVC
PVC valve hoses
vacuum hoses
fuel filter
fuel pump
air filter
idle control valve
Thanks in advance
Tuesday, December 20th, 2016 AT 10:31 AM (Merged)
HMAC300
  • 48,601 POSTS
Check fuel pressure with a gauge first. See pic for causes it may be temp sensor or anO2 sensor if you got a bosch one those are not very good also check for an air leak through duct work leading to throttle then check sensors with chart I'm sending.
KRYPTECLIPSE
  • 45 POSTS
Thank you will do this in the morning
KRYPTECLIPSE
  • 45 POSTS
Thank you very much. This really helped a lot. What turned out to be was the brake booster vacuum hose. Replaced and car is running smooth again. Tiny vibration on steering wheel but it is not failing out on me. If you got any idea what that might be let me know. Thanks again
HMAC300
  • 48,601 POSTS
Vibration can be anything for exhaust hitting body to tires have it check locally
KRYPTECLIPSE
  • 45 POSTS
Thanks I will check it out
BLUE ANGEL
  • 8 POSTS
  • 2003 MITSUBISHI ECLIPSE
  • 4 CYL
  • FWD
  • 102,000 MILES
Computer problem
2003 Mitsubishi Eclipse 4 cyl Front Wheel Drive Automatic 102000 miles
what is wrong with the car when it has these two codes po 171 and po 300?
P0171/P0300 random misfire
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. (Use a fuel pressure gauge to check fuel pressure at idle)
* Dirty fuel injectors. (Try cleaning the injectors)
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body. (Use a vacuum gauge to check for low intake vacuum)
* Leaky EGR valve. (Check operation of EGR valve)
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). (Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires)
KRYPTECLIPSE
  • 45 POSTS
  • 2.0L
  • 4 CYL
  • 80,000 MILES
I am getting this code. I have done some work to the car but the light is still on. The only thing I noticed differently is that it has a rough idle when in the stop lights. Some times when I get out the car has a smell of gas. These are the things I have changed:
O2 sensor
pcv
pcv valve hoses
fuel filter
Thanks in advance
