Is this a hose or a steel tube? That steel tube should be part of an air injection system for the catalytic converter and aids in the conversion of NOx gases and CO into harmless Nitrogen and Oxygen. A bad catalytic converter will be accompanied by bad gas millage, hesitation, and with a variable or low engine vacuum as indicated by a vacuum guage. If there seems to be no engine problems a shop can weld on a tube for your air injection pump. I am also assuming the air injection system is operational otherwise you will be irritated by constant backfiring through the diverter valve.
SPONSORED LINKS
Wednesday, June 18th, 2008 AT 11:22 PM
