Is there any way at all to pull the codes out of a 94 Olds Cutlass Ciera without buying a $100.00 scan tool? Terminal B in the diagnostic connector is not there so I can't just short it to flash the codes. Is there another terminal somewhere else (under the hood or somewhere else under the dash or anywhere else) that can be shorted to flash the codes? Can I turn the ignition key in a certain series of on and off in order to flash the codes?
Feb 28, 2010 at 8:49 PM
