Engine Mechanical problem
1997 Oldsmobile Bravada 6 cyl All Wheel Drive Automatic
I recently had this issue where the car would crank yet it would not turn over. Took to the mechanic and they replaced the coil and crank sensor. And now it continues to have the same issues. The battery is under a year old. The electrical is good with no faults that I can find. Car does not start with a jump either. Vacuum lines are intact. I have run out of ideas as to where to look for problems to fix. Any suggestions?
Mar 20, 2010 at 2:26 PM
