I was wondering why my hazard light button keep clicking? The button works but when it's not on it still has a random clicking, thanks.
Mar 3, 2012 at 12:34 AM
CAR REPAIR CONTRIBUTOR
That is odd. Check to make sure everything is tight and grounds are good.
Mar 3, 2012 at 3:26 AM
ANDY11BARTON
MEMBER
Thank You
Mar 3, 2012 at 4:56 AM
JAMESCARS123
MEMBER
try cleaning the inside of the multi-function switch on the turn signal side
Nov 7, 2018 at 7:46 AM
Did that fix your problem?
Nov 9, 2018 at 12:34 PM
RKNIGHT733
MEMBER
When you turn the signal on after it turns off the clicker continues to click till you turn again without turning the signal on. what causes this?
(Merged)
RKNIGHT733
MEMBER
No the lights stop flashing. Just an annoying noise. dont know where to start
(Merged)
JAMESCARS123
MEMBER
try cleaning the contacts inside the multi-function switch
(Merged)
TURBOJAY
MEMBER
I had this problem it was the hazard switch
Aug 29, 2019 at 11:45 AM
LIZREED
MEMBER
1 POST
I have a 2001 Alero with a clicking noise from the hazard switch. The directionals and hazards work properly, but when they are not on I get a fast clicking noise from the hazard switch constantly. I replaced the switch, but the noise continues. Could it be a bad brand new switch? bad directional signal switch?
Any thoughts.
Aug 29, 2019 at 11:46 AM
(Merged)
RHALL77
it very well could be, there was a campain at the dealers to replace that switch. I know even they had a batch of bad ones. I would check into a different switch
(Merged)
OLDS ALERO
MEMBER
Its not the Hazard switch, the hazard switch is just responding to the bad inputs from the multifunction switch.
Lizreed,
Thanks to your own re-post I also cleaned the contacts of the turn switch in the mulit-function swicth on my 2002 alero and the clicking sound went away!!!!
Thanks!!!
(Merged)
