2000 Oldsmobile Alero COOLANT LEAK
2000 OLDSMOBILE ALERO
97,000 MILES • 4 CYL • 4WD • AUTOMATIC
KNIGHTRESS
I HAVE A 2OOO ALERO. A FEW DAYS AGO, A WARNING LIGHT INDICATING THAT SOMETHING WAS GOING ON WITH THE COOLENT. I FILLED THE RESEVOIR, AND THOUGHT THAT THAT SOLVED THE ISSUE. TWO LATER THE WARNING LIGHT CAME ON AGAIN. I CHECK THE COOLANT LEVEL. IT HAD LEAKED OUT. I REFILLED IT. TWO DAYS LATER IT HAD LEAKED OUT AGAIN. IT IS A SLOW LEAK. IT DOESN'T APPEAR TO BE COMING FROM THE RESEVOIR, NOR ANY OF THE BELTS. HELP!
Sep 2, 2009 at 4:20 PM
