My fuel gauge will not register the correct amount of fuel in tank. It will go to full when started but as you drive the low fuel light will come on and the gauge will stop working. Also when refueling the gas pump won't shut off when full ? I figure the vent on the filler neck is causing the problem on the fill up, but wonder if both problem are related, some one told me it could be a PIN failure ?
Jun 26, 2008 at 8:44 AM
