Mechanics
KNOCK SENSOR SHOWING HIGH OUT PUT
2003 Nissan Xterra
Engine Mechanical problem
2003 Nissan Xterra 6 cyl Two Wheel Drive Automatic 96000 miles
WHERE IS THE KNOCK SENSOR LOCATED SHOWING HIGH OUT PUT I WAS TOLD THIS MEAN IT IS OVER TORQUED IF SO WHAT IS THE TORQUE SPEC AND WHERE IS IT LOCATED ON A V6 CAN IT BE REACHED EASY WITH HAVE TO REMOVE HAVE THE ENGINE DO I NEED A SPECIAL TOOL
Richardmcm
April 26, 2008.
The knock sensor is located on top rear of engine see item no.3 below
http://www.2carpros.com/forum/automotive_pictures/12900_ks_3.jpg
AD
Rasmataz
Apr 26, 2008.
The only problem I have with this picture is that it doesnt tell u that the knock senser is located under the lower intake manafold asmb the upper and lower intak manafold must be removed too replace this part it is a very involved repair lsauto
Lsauto
Mar 30, 2009.
AD
