spark plug order
1997 NISSAN TRUCK
227,000 MILES
DRIPPER
  • 11 POSTS
On a 2.4 liter engine for the truck listed above looking from left to right at plugs which one is number two cylinder?
Aug 11, 2012 at 5:29 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
Here is the engine spark plug firing order. Check out the diagrams (below). Please let us know if you need anything else to get the problem fixed. Cheers
Aug 11, 2012 at 6:09 PM
Here is the engine ignition firing order check the v6 diagrams below (click to enlarge)
https://images.2carpros.com/forum/automotive_pictures/12900_fo_49.jpg
Jun 30, 2018 at 11:29 AM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
2.4 engine fire order
Dec 11, 2018 at 2:01 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Greetings
Below is a diagram of your vehicle's firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
ARONCRU
Electrical problem
1993 Nissan Truck 4 cyl Two Wheel Drive Manual
i have one plug that comes out next to the alternator plug that i can not find anything that would connect to it. do you know or have a wiring diagram in this area that may help me find out what this plug gose to? the two wires going in to the plug are black and green.
Oct 16, 2020 at 6:03 PM (Merged)
Hi aroncru and welcome to 2carpros Below is your alternator wiring connector colors
https://images.2carpros.com/forum/automotive_pictures/12900_alty1_3.jpg
