2CarPros - Car Questions & Answers
1993 Nissan Truck Repair Question
Topics covered: Spark, Engine, Clutch.
Asked on May 16, 2010
1993 Nissan Truck
Engine Mechanical problem
1993 Nissan Truck 4 cyl Two Wheel Drive Manual
turned truck off went to start it will not start even tried popping the clutch
Avatar Asked by flonitegale
Answer
Replied on May 22, 2010
Pick your symptom:
**Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
**No crank at all/nothing/nada:
Could be a blown fusible link, the starter, starter relay, clutch switch/park and neutral switch and ignition switch assuming the battery and connections are good.
Tiny Answered by rasmataz
68 questions asked
