Timing belt marks and replacement instructions
2002 NISSAN QUEST
90,000 MILES • 6 CYL • 2WD • AUTOMATIC
MADEJOSE
I have heard that this car was built by Ford under an agreement that the engines would be free running/non-interference thus not bending valves. Is this true? I just want to know before I start the job.
Jose
Mar 3, 2011 at 5:10 PM
  • CAR REPAIR CONTRIBUTOR
  • 54,350 POSTS
I checked it out on RockAuto and this is what they say
"Camshaft; Non Interference Engine"
So it could have bent valve. I would remove the both valve covers and rockers then do a leak down test to see if any are bent.
Here is how the timing belt job is done and the marks.
https://www.2carpros.com/diagrams/nissan/quest/2002
Nov 18, 2017 at 8:29 PM
SMIRKY10
I replaced a timing belt and water pump on a 2002 Nissan quest. The timing marks were aligned according to the notches on the timing belt cover and crankcase. when I start the engine it runs,sputters and shuts off. Did I align the timing marks for the exhaust cycle, and if so, how do I align the timing marks properly for the compression cycle.
May 4, 2021 at 1:22 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
Did T belt brake while driving? This motor is a non interference motor. Valves and pistons cannot be damaged because they have enough clearance in the event of T-belt failure. If not see diagram if lined up on intake cam then it is correct.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_535.jpg
AMILCAR
Do I need to drop the engine on a Nissan Quest to change the timing belt?
BMRFIXIT
  • 19,053 POSTS
Disconnect negative battery cable. Remove the engine undercover. Drain coolant and remove the radiator. Remove engine cooling fan and water pump pulley. Remove accessory drive belts. Remove spark plugs.
Remove distributor protector. Remove A/C compressor drive belt idler bracket. Remove fresh air intake tube from rocker cover. Remove thermostat housing hose.
Rotate crankshaft to set No. 1 cylinder at TDC on compression stroke.
. Remove crankshaft pulley bolt and remove crankshaft pulley. Remove front upper and lower timing belt covers
Align punch mark on left camshaft sprocket with punch mark on timing belt upper rear cover. Align punch mark on crankshaft sprocket with notch on oil pump housing.
Install crankshaft pulley bolt so that crankshaft can be rotated.
Loosen timing belt tensioner nut.
Turn tensioner, and remove timing belt.
2CP-ARCHIVES
  • 4,540 POSTS
1999 Nissan Quest mileage: 60,000. I'm getting mixed answers on what mileage to change the timing belt. When do you think? And, if it breaks, is it going to be a large repair, or just replace the belt?
May 4, 2021 at 1:23 PM (Merged)
2CP-ARCHIVES
  • 4,540 POSTS
Your engine’s timing belt should be replaced at 60,000 miles. It is cheaper to replace the belt before it fails.
AMSERIES
what if it is a 3.3 litre will it bend or not. thanks
