Location of Crankshaft sensor
LINDACAROLKLEIN
  • 2000 NISSAN QUEST
  • 125,000 MILES
2000 nissan quest gxe: where is the crankshaft position sensor located?
Monday, February 7th, 2011 AT 11:49 PM
Here is a guide that will walk you through the steps and a diagram below to show the location for your car.
Monday, February 7th, 2011 AT 11:53 PM
1S3XYD4D
  • 1999 NISSAN QUEST
I need to replace the sensor, just can't find it's location
Wednesday, January 2nd, 2019 AT 7:16 PM (Merged)
DOCFIXIT
  • 18,828 POSTS
On transaxle housing facing flywheel teeth
GENE24BLUBMW
  • 1996 NISSAN QUEST
Electrical problem
1996 Nissan Quest 6 cyl Front Wheel Drive
where is the crank sensor on a 3.0 nissan quest
Crankshaft Position Sensor
ECCS Components Parts
https://www.2carpros.com/forum/automotive_pictures/12900_cps1_11.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_cps2_8.jpg
LINDACAROLKLEIN
  • 2000 NISSAN QUEST
  • 125,000 MILES
What is the function of the crankshaft position sensor and could replacing it improve gas mileage?
FIXITMR
  • 9,990 POSTS
The camshaft position sensor is a magnetic or hall effect sensor, this sensor reads information about the engine, camshafts and speed. It sends a signal to the computer relaying information about shaft speed, position and acceleration or deceleration. The function of the camshaft position sensor is important for the vehicle to run at its best, and maintaining a high level of performance and fuel economy. The information given to the ECU or the Electronic Control Unit dictates when the air fuel mixture is ignited and when to give more or less fuel in correspondence with the camshaft position, its speed and subsequently the valves position and speed. This is a very simple sensor to replace and service, and yet it serves a huge role in your vehicles performance and overall health.
WRENCHTECH
  • 20,758 POSTS
The Crankshaft Position Sensor provides the reference signal to the PCM for spark and injector pulse and no, it won't effect mileage.
BOLADOR405
  • 1999 NISSAN QUEST
  • 120,000 MILES
Have 1999 nissan quest 3.3, gime the code po1336 crankshaft sensor camshaft sensor range. Change crankshaft sensor and reset code still misfire, can any body helpme what it is, or what I need to do.
Thank you for your help
DOCHAGERTY
  • 9,601 POSTS
Misfiring is not the same as a set fault for the crankshaft sensor. Was the misfire fault there all along or is it showing up now that the crankshaft sensor has been replaced?
BOLADOR405
The misfire fault was there all along.
DOCHAGERTY
  • 9,601 POSTS
Inspect the ignition components for possible failures. Have the sparkplugs been recently replaced?
