Fuel filter replacement
66IMPALAD
  • 1999 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 125,800 MILES
Where is the fuel filter located at on my truck
Thursday, May 7th, 2009 AT 3:00 PM
Under the rear of the truck, above the rear axle, passenger side
Here's a guide on replacing the filter
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
See the picture below for location
Thursday, May 7th, 2009 AT 5:12 PM
OPSGUY21
  • 4WD
Where is the fuel filter for a 1999 pathfinder located
Wednesday, October 3rd, 2018 AT 6:24 PM (Merged)
  • 108,139 POSTS
Under the hood on the passenger side. It's mounted on the front side of shock tower, in fuel line
TAMPICO
  • 1987 NISSAN PATHFINDER
  • 4 CYL
  • 4WD
  • MANUAL
  • 324,000 MILES
Sputter, not severly
Sometimes will sputter so bad it dies
New, plugs, plug wires, dist. Cap, rotor,
Fuel filter,
Problem does not appear to be fuel deli
Very issue, observe consistant fuel into
Trottle body
"brain" appears to be in working order
No visual defects(bured diods, relays)
Wires to "brain" arrear fine
Will start and idle cold or hot
Though still occationally sputter
Engine does smoke, but not severly
Most of the time cant see any
Saturday, March 30th, 2019 AT 7:52 AM (Merged)
KHLOW2008
  • 41,815 POSTS
Hi TAMPICO,
Thank you for the donation.
Thee are various possibilities such as :
1. Throttle position sensor.
2. Air flow meter (AFM). Check if the sensor inside air flow is dirty. Use air flow spray cleaner to clean it. Be careful not to damage it with any physical contact.
3. Crank angle sensor.
4. Cylinder head temperature sensor.
Is the Check Engine Light showing?
Did you try to go into diagnostics.
UMUHEHE
  • 2005 NISSAN PATHFINDER
Six cylinder two wheel drive Automatic 72,730 miles.
Could you please help me with the fuel filter location on the car? I have search for it but I was unable to locate it.
Thanks in anticipation.
Umuhehe
BLUELIGHTNIN6
  • 16,542 POSTS
The fuel filter is located under the vehicle near the fuel tank.
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_1778.jpg
DATNUMBA
  • 2003 NISSAN PATHFINDER
  • 6 CYL
  • 4WD
  • 39,855 MILES
I need to change fuel filter where is it located on the truck
KACEY
HI
It is located between the sapare wheel & the rear axle. You need to get under & see it will be mounted along the axle towards the spare wheel. (Floor mounted spare wheel)
regards.
Saturday, March 30th, 2019 AT 7:53 AM (Merged)
