starter
1997 NISSAN MAXIMA
MEALLEN
Where is the starter located?
Aug 21, 2007 at 9:41 AM
  • CAR REPAIR CONTRIBUTOR
[quote:2e6ed1a21a="MEALLEN"]Where is the starter located on the 1997 Nissan Maxima[/quote:2e6ed1a21a]
Its in between the engine and transmission-follow the positve battery cable's other end-you'll find it.
Aug 25, 2007 at 5:10 PM
WOODY1950
Engine Mechanical problem
1997 Nissan Maxima 6 cyl Front Wheel Drive Automatic
i have a 1997 nissan maxima v6 and i cant find the starter
Apr 19, 2019 at 2:11 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi woody1950
If you follow the cable from the battery positive terminal, you would end up with the starter.
Not many tools required, but flexible hands helps. You need 12 mm, 14 mm ring and box spanners.
Remember to remove battery negative terminal fiirst.
DAN123
1996 Nissan Maxima
were is the starter located on a 1996 nissan maxima
BLUELIGHTNIN6
  • 16,542 POSTS
Just follow positive cable battery down through engine compartment if you have difficulty finding starter. To remove starter, disconnect negative battery cable. Raise and support vehicle if necessary. Disconnect starter wiring. Remove starter mounting bolts and starter.
JPTS11
Electrical problem
1990 Nissan Maxima 6 cyl Front Wheel Drive Automatic
where is it located how to change
The solenoid is within the starter where your battery positive cable hooks up to and the starting circuit
