2CarPros - Car Questions & Answers
2006 Nissan Altima Repair Question
Topics covered: Sensor, Crankshaft, Camshaft.
Asked on February 6, 2010
2006 Nissan Altima camshaft & crankshaft sensor
Engine Mechanical problem
2006 Nissan Altima 4 cyl Front Wheel Drive Automatic
were r ur camshaft & crankshaft sensor?
Avatar Asked by ernest fuentes
Answer
Replied on February 6, 2010
Hi ernest fuentes,
Thank you for the donation.
The Camshaft sensor is located at rear of cylinder head. Item # 16 is tha cam sensor.
http://www.2carpros.com/forum/automotive_pictures/192750_CamSensor06Altima25LFig50_1.jpg
The crankshaft sensor is located on right rear of cylinder block, facing the gear teeth ( cogs ) of the signal plate at end of crankshaft, below the starter motor. Item # 3 is the crank Sensor.
http://www.2carpros.com/forum/automotive_pictures/192750_CrankSensor06altima25LFig152_1.jpg
Tiny Answered by KHLow2008 (expert)
39,956 answers provided
Hello ernest fuentes
The camshaft sensor is located by the driver side, Below Throttle Body.
http://www.2carpros.com/forum/automotive_pictures/46384_AltimaCrankshaftCamshaftSensorReplacement038_1.jpg
The crankshaft sensor is located is located driver side rear side of engine.
http://www.2carpros.com/forum/automotive_pictures/46384_AltimaCrankshaftCamshaftSensorReplacement039_1.jpg
In the above photos you can see the location of the camshaft sensor on the driver's side of the engine and the crankshaft position sensor is down on the back side of the engine (best seen from under the car & removed from above).
To replace either sensor you will need a 10mm metric bolt and a ratchet wrench. Don't forget the rubber o-ring. You're done!
Tiny Answered by mathiaso
5 questions asked
