1998 Nissan Altima Oil in cylinders causing a misfire
1998 NISSAN ALTIMA
KJACK72
Engine problem
1998 Nissan Altima 4 cyl Front Wheel Drive Automatic 80xxx miles
Recently I was replacing the spark plugs and found oil accumulated in the cylinder around the spark plug wire. I thought someone had just carelessly spilled oil in there during an oil change, so i cleaned it out. After checking it again today, i found it wet with oil again.
Any idea where this is coming from?
Feb 10, 2008 at 2:05 PM
  • CAR REPAIR CONTRIBUTOR
Check the valve cover-if not there as you said its misfiring-could be rings/valves-Do a dry and wet compression to determine where its coming from.
Feb 10, 2008 at 2:18 PM
