1998 Nissan Altima Repair Question
Asked on March 28, 2009
My trunk
1998 Nissan Altima
for some reason unknown to me my trunk will not open wen i pull the trunk release lever and i cannot turn my key wen it is in the trunk key hole if u could help me to figure out the problem it would b greatley appriciated
Answer
Replied on March 29, 2009
You may have inadvertently push the lever inside the trunk to LOCK position. That will disable the remote release from the driver seat.
The trunk key hole is probably rusted out. My trunk key has not worked since 1997.
Pull the two tabs on the back seat to gain access to the trunk. Locate the lock latch release tab, close to the trunk latch. Push up to UNLOCK position. Remote release should work now.
