ok. my car was starting up but when it start up it made noise between the flywheel so i toke the engine out and tighten the flywheel bolts. so when i put the engine back in it would not start.so i check to see if it is firing and it was not firing so i change the hold distributor. so what must i do now or to check to get it firing. the engine was running good. it has no spark
Apr 25, 2009 at 2:25 PM
