Serpentine belt diagram
KOOLPOP
  • 1999 NISSAN ALTIMA
  • 4 CYL
  • MANUAL
  • 10,000 MILES
I need to know the correct way to install the alternator belt. I have it on, but I am not sure if it is correct?
Thursday, October 21st, 2010 AT 6:23 AM
DOCFIXIT
  • 18,828 POSTS
Hello.
Here is a link that shows all the engine options and belts and how to change them out
https://www.2carpros.com/diagrams/nissan/altima/1999
Thursday, October 21st, 2010 AT 9:42 AM
MELSHORT
  • 1997 NISSAN ALTIMA
I have the belt but cant quite figure it out
Monday, February 18th, 2019 AT 2:29 PM (Merged)
  • 52,797 POSTS
Yes, it appears that it does.
KHLOW2008
  • 41,815 POSTS
A/C belt is on outer ring of pulley and has to come off first.
CHARLES18340
  • 1995 NISSAN ALTIMA
How to remove serpentine belt from 1995 nissan altima
  • 108,179 POSTS
There is a tensionier that holds the belt in place. The automatic tenionier turns. Take a wrench and turn the tensionier in the direction to loosten the belt and slip the belt off.
MICHAEL GAYLE
  • 4 CYL
  • FWD
  • 128,332 MILES
I would like to get some info on how to install new drive belts on my 1997 nissan altima myself. I am not even sure if there is more than one belt or one serpentine belt. Also, is there some sort of guide or handbook I could purchase to assist me with these types of maintenance procedures?
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_97altimabelt_1.jpg
https://www.2carpros.com/forum/automotive_pictures/55316_97altimabeltdeflect_1.jpg
You have two serpentine belts. A larger one controls all but the AC pulley, an the smaller one runs that.
Yes, I suggest that you purchase Haynes manual 72016 (covers Altima from 1993 through 2004).
ZACKMAN
  • 4,202 POSTS
Once you have the manual, turn to page 1-17.
Adjustment - all models except the 2.5L engine.
Belt tension is adjusted by moving the idler pulley. To adjust the belt, loosen the lock nut (or adjuster) and turn the idler pulley adjusting bolt (usually on the bottom).
Replacement - all models except 2.5L engine
Loosen the drive belt adjustment bolt, slip the belt off the crankshaft pulley and remove it.
Remove the AC belt first to gain access to P/S, Alt, W/P belt. It is a very good idea to remove both belts at the same time.
Mark each belt and its appropriate pulley groove so the replacement belts can be installed in their proper position.
JDOUGLASB
Engine Mechanical problem
1997 Nissan Altima 4 cyl Two Wheel Drive Automatic
Belt broken so need diagram to replace
BLUELIGHTNIN6
  • 16,542 POSTS
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_227.jpg
JOSHETTA
  • 1998 NISSAN ALTIMA
1998 Nissan Altima
What is the serpentine belt routing for 1998 nissan altima GLE.
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/car_repair_information/tec_info/1997/nissan/altima/1997_nissan_altima_drive_belt_routing_diagram.htm
'98 should be the same
