1997 Nissan Altima 1997 Nissan Altima - Fluctuating RPM gua
1997 NISSAN ALTIMA
84,000 MILES • 4 CYL • FWD • AUTOMATIC
1997ALTIMAOWNER
The car when running down the road at typical speed of between 30 and 50 mph will experience fluctuations, mild to moderate, in the RPM guage and the associated idle of the vehicle, seeming to nudge or lose power slightly going down the road. By driving fast and aggressive the symptoms can be overcome; however, there is definate smell of unburned fuel in the air as you come to a stop. At times when you come to a stop at a stop sign when this behavior is occurring, the car will literally flutter to a stop and go dead. It will immediately crank again but may or may not behave the same way again. Additionally, if the vehichle is exibiting the behavior it can sometimes correct itself if we pull over, turn the engine off, and start the engine again. The problem is somewhat intermittent in that sometimes when you crank it and drive the care seems to be ok; but the next time it is started, it may exibit the behavior. It is growing more frequent in last couple of weeks. The car is driven only for short trips to the market about 5 miles away so it does not see frequent and long trips on the highway. There are no engine lights illuminated on the dash which would point to emmissions related items and the battery and alternator systems have been tested satisfactory. The engine is a 2.4 L 4 cylinder automatic. 1997 is the year model of the Nissan Altima with front wheel drive and 84000 miles.
Jul 26, 2008 at 1:06 PM
