fuel pump relay
1989 MITSUBISHI MONTERO
200,000 MILES
AMILCAR
I don't have any power at the pump's plug so I suspect a relay problem.
Feb 12, 2012 at 11:35 PM
  • CAR REPAIR CONTRIBUTOR
Best power the F/Pump and see if it turns before you start at the relay since you're there
Feb 12, 2012 at 11:39 PM
AMILCAR
It does turns. I had to replace it since the old one was dead. But there is no power at the plug.
Feb 12, 2012 at 11:46 PM
AMILCAR
Any idea where the relay might be? Or if it has a fuse some where other than the regular fuse box?
Feb 12, 2012 at 11:52 PM
Check the MPI control relay on right side kick panel, its what controls the fuel pump
Feb 13, 2012 at 12:05 AM
LITTLENEWYORKER02
Four cylinder two wheel drive automatic.
We are changing the fuel pump in our vehicle, but they are wanting to make sure it is not the fuel pump relay. We are having trouble locating which one that relay is? Help please.
Jun 3, 2019 at 6:29 PM (Merged)
It is behind right side of dash above the computer.
https://images.2carpros.com/forum/automotive_pictures/12900_Fp_relay_2.jpg
