2003 Mitsubishi Galant
TANK33
  • 2003 MITSUBISHI GALANT
  • 4 CYL
  • 168,326 MILES
WHERE IS THE FUEL FILTER THAT IS, NOT IN THE FUEL PUMP OR GAS TANK, LOCATED IN A 2003 MITSUBISHI GALANT.
Friday, March 11th, 2011 AT 10:04 PM
  • 31,938 POSTS
There is no external filter on the in tank filter.
Friday, March 11th, 2011 AT 11:11 PM
CLINTON M. BROTHERS
  • 2000 MITSUBISHI GALANT
  • 125,000 MILES
Were is the fuel pump kill switch located at?
Friday, March 1st, 2019 AT 7:12 PM (Merged)
HMAC300
  • 48,601 POSTS
Some cars have it others do not. All are put into PCM to shut off fuel at a certain rpm's like in the 5000 rpm's range. Yours does not have it. It has a relay and PCM tells relay to go on to pump fuel as well as oil pressure switch when started.
NPAUL7474
  • 2007 MITSUBISHI GALANT
Engine Mechanical problem
2007 Mitsubishi Galant 4 cyl Two Wheel Drive Automatic
My car wont start and acts like its not getting any gas. The engine will turn over but it doesnt seem to be getting any fuel. Could it be the pump or the filter if so where are they located.
Cranks but no start condition-do below:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
WILMOUTH7
  • 2001 MITSUBISHI GALANT
  • 4 CYL
  • 164,000 MILES
Car died going down road. Will crank, but not start. Tried to flood it, but cant smell gas. It's acting like its not getting fuel to it. Could it be filter or pump. If so wherer are they located?
Thanks in advance,
jim
Cranks but no start condition-do below to determine whether it's fuel or spark related problem:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, Do you hear the fuel pump come On when you turn key on? If not check fuel pump fuse and fuel pump relay if so, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
