Timing belt
ANGELD1993
  • 1999 MITSUBISHI GALANT
  • FWD
Where is the timing belt located on a 1999 mitsubishi galant
Thursday, February 24th, 2011 AT 4:40 AM
TOMSHANTY
  • 34 POSTS
There is an access plug in the upper portion of the timing cover so that the timing belt can be checked without removing entire cover. Check out this guide to help see how to change the belt with the timing marks
https://www.2carpros.com/diagrams/mitsubishi/galant/1999
Thursday, February 24th, 2011 AT 5:14 AM
KHLOW2008
  • 41,814 POSTS
Timing belt is inside the cover.
Thursday, February 24th, 2011 AT 3:01 PM
CARIDIDDY
  • 1996 MITSUBISHI GALANT
  • 4 CYL
  • FWD
  • 100,800 MILES
I work for a car dealership, so I have the mechanics there do the maintenance on my car. I told one of the mechanics that I thought it was time for my timingbelt/water pump to be changed. He later reported that after looking up the info on my car, that it has TWO timing belts or something to that effect. I've been trying to find out on the internet if this is true, but can't find anything on it. HELP!
Monday, September 7th, 2020 AT 11:37 AM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi Carididdy,
Yes, there are indeed 2 belts, main timing and balancer belt.
Item 35 is balancer belt and 24 is the timing belt.
https://www.2carpros.com/forum/automotive_pictures/192750_Tbelt96Galant_1.jpg
MX045203
  • 1995 MITSUBISHI GALANT
  • 4 CYL
  • FWD
  • 200,000 MILES
In the follwing link,
http://www.2carpros.com/car_repair_information/year/1995/make/mitsubishi/model/galant/1995
Instructions are very clear I have one small doubt. The a measurement "A" between the timing belt auto-tensioner and the Tensioner pulley bracket (diagram shown on page 4) , where I can find this measurement.
Thanks to al that repond.
BLUELIGHTNIN6
  • 16,542 POSTS
Have to measure the auto tensioner rod protrusion between auto tensioner housing and the point where it contacts the tensioner arm. The protrusion should be.150 -.177". Is this what you are talking about?
MX045203
The issue is the time belt broke off, the protrusion of auto tensioner is fully deployed, since tensioner pulley bracket released at time of breakage. (Know I have to reload the auto tensioner). Is this the spec. Measurement that should be in place if I was to rebuild to OEM Specs.
Thanks
BLUELIGHTNIN6
  • 16,542 POSTS
Yes specs in last post are what it must be
OLSONJJ
  • 4 CYL
  • FWD
  • 147,000 MILES
What is the timing on a 95 mitsubishi galant?
BLUELIGHTNIN6
  • 16,542 POSTS
You need timing marks or the firing order?? timing marks are below......
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic_238.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Graphic2_26.jpg
CZARGAT
Engine Mechanical problem
1995 Mitsubishi Galant 6 cyl Front Wheel Drive Automatic
I need to know the timing marks on my car because the marks that I see does not seem right and the car has no power
BLUELIGHTNIN6
  • 16,542 POSTS
Timing marks below are for the 2.4L engine. Let me know if your engine size is different.
(((Silent shaft alignment marks)))
https://www.2carpros.com/forum/automotive_pictures/261618_silent_1.jpg
(((Timing belt pulley alignment marks)))
https://www.2carpros.com/forum/automotive_pictures/261618_0900c15280037dba_1.jpg
Thanks for using 2CarPros.com!
USWEDL41
  • 4 CYL
  • FWD
  • 198,000 MILES
I am hoping you can help me figure out how to line up the timing marks on my Galant. On the upper pulley, there is a notch on one of the teeth and a circle on one of the spokes. I have a Haynes manual, but the manual does not seem specific and is very confusing. The manual also states there is a timing mark for the upper pulley on the engine case. I cannot find one in the same area the manual says on my vehicle, but I see a mark on the valve cover. Is the mark on the valve cover the correct one?
For the lower pulley, can you please advise where the timing marks are?
Thank you in advance for your help.
See below
https://www.2carpros.com/forum/automotive_pictures/12900_t1_7.jpg
https://www.2carpros.com/forum/automotive_pictures/12900_t2_5.jpg
BELLYBUTTONHEAD20
  • 1994 MITSUBISHI GALANT
  • 4 CYL
  • FWD
  • 180,000 MILES
What causes a timing belt to break?
  • 108,328 POSTS
Timing belts wear from use and time. The only other thing that can cause it to break is if something locked up.
Worned tensioner and guides
BMRFIXIT
  • 19,053 POSTS
THEY SHOULD BE REPLACED EVERY 65,000 TO 80,000 MILES
IF NOT THEY FAIL AND BRAKE
KEVCULMSTOCK
  • 1991 MITSUBISHI GALANT
Can I see a timing mark diagram for a 1991 mitsubishi galant 4g63 2.0 sohc engine?
Here is the timing marks and belt routing for your car
https://www.2carpros.com/diagrams/mitsubishi/galant/1991
Cheers
