Mechanics
CHECK ENGINE LIGHT } TROUBLE CODES
1999 Mitsubishi Eclipse
Engine Mechanical problem
1999 Mitsubishi Eclipse 4 cyl Front Wheel Drive Manual 140000 miles
After the check engine light has been cleared and the problem fixed, If I ran another scan on it, will the check engine light that provides the trouble codes tell me everything I had once already fixed?
I have already changed the fuel pump, fuel filter and relay but my car still dies after a minute of running. It dies as if the fuel has been cut off, like ni pressure is behind it. The only thing I have been able to come up with is it could possibly be the fuel pressure regulartor. AM I correct or could there be something else that I am over looking?
Thank You
Barbara
AD
Fantasia
May 23, 2009.
Hi Barbara,
What were the codes you got?
Once you fix a problem and clear the codes they shouldn't come back. Unless there is a problem with something else on the circuit.
You should go ahead and check the fuel pressure and regulator.
Obxautomedic
May 23, 2009.
AD
