OBD II Code P1443
MERCURY TRACER
EARTHGIRL1975
My car is a 1997 LS model with 123000 miles on it. The check engine light is on and getting code P1443. According to Advance Auto and Autozone it is "Evaporative emission control system control valve", what ever that means. The guy at Advance suggested changing the wiring harness, does this sound right? What do i need to do to get this problem fixed?
Mar 11, 2007 at 11:48 AM
MERLIN2021
  • CAR REPAIR CONTRIBUTOR
  • 17,250 POSTS
This valve is under the hood near the engine I would check the valve lines to make sure they are in good shape here is a diagrams below to help you.
Mar 11, 2007 at 8:09 PM
CHEVY22
  • 1,375 POSTS
You are close. it is the evaporative control system purge valve malfunction. it means the purge valve is bad. you do not need a harness. That is funny, that is all you need. It is on the drivers side of the engine compartment. I would send you a diagram but you would not be able to see it.
Jim
Mar 11, 2007 at 8:16 PM
SERVICE WRITER
  • 9,123 POSTS
did this come on since you last filled your fuel tank?
Mar 11, 2007 at 8:43 PM
EARTHGIRL1975
I called a Ford Dealership this morning and gave them the code. They said there was definitely a leak somewhere in the emissions system. They said a smoke test on emissons needed to be performed. And that it was probably the canister purge valve or the hose leading to the intake leaking. I am having a place do the smoke test for $30.00 tomorrow. Then I will replace the part or parts that leak. Thanks so much for the help again, much appreciated.
Mar 12, 2007 at 9:25 AM
MERLIN2021
  • 17,250 POSTS
Great price on that test!
Mar 13, 2007 at 4:13 PM
CHEVY22
  • 1,375 POSTS
No doubt that is super inexpensive. we get 1.5 hrs for it $140.00. but that does include lemon or orange flavor.
Mar 13, 2007 at 4:21 PM
EARTHGIRL1975
No this code has been on for a while. Thanks for the information guys. I replaced the valve the problem is fixed! I love this site.
Mar 20, 2007 at 2:01 PM
CHEVY22
  • 1,375 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
Jul 13, 2007 at 10:38 AM
JAYHAWKFAN64
where is the evaporative emmision control system control valve located on an 1997 Mercury Tracer?
Nov 20, 2018 at 11:39 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Evaporative Emission (EVAP) Purge Flow Sensor located On left side of engine compartment
