Air conditioner clutch relay?
JOHN LICARI
  • 1995 MERCURY SABLE
  • 6 CYL
  • 122,900 MILES
Where is the A/C clutch relay?
Tuesday, August 17th, 2010 AT 6:49 AM
WRENCHTECH
  • 20,758 POSTS
The compressor relay is incorporated into the CCRM (Constant Control Relay Module), also known as the Integrated Controller. It's located on the front radiator support, right above the fan.
https://www.2carpros.com/forum/automotive_pictures/561653_CCRM_94_Taurus_1.jpg
Tuesday, August 17th, 2010 AT 7:48 AM
AMBJJR
  • 2002 MERCURY SABLE
Air Conditioning problem
2002 Mercury Sable 6 cyl Front Wheel Drive Automatic
A/c clutch is not engagig. New compressor and clutch! I read that I may have to jump tje safety switch. Where is it and how might I do this?
Friday, June 28th, 2019 AT 6:02 PM (Merged)
At the AC clutch solenoid check for power at the black and yellow wire if none test the AC clutch relay-Or do this apply battery voltage to the black and yellow wire and see if it'll engage the compressor.
OIDAVEY
  • 0 POST
I had this problem and replaced the compressor fixed it right up.
I used this guide
https://www.2carpros.com/articles/replace-air-conditioner-compressor
Tuesday, October 1st, 2019 AT 5:38 PM
