Electrical problem
2000 Mercury Mystique 6 cyl Two Wheel Drive Automatic
I would like to clarify what "Code P0190" means. I believe it is "Fuel Rail Pressure Senser Circuit Malfunction." I changed the fuel filter and the fuel pump. After changing the fuel pump the car would start and stay running for awhile only if i sprayed starter fluid in the intake, once I stopped spraying the starter fluid the car would "die".
Thank you for your time.
Jan 16, 2010 at 1:52 PM
