Heater problem
1994 Mercury Marquis V8 Two Wheel Drive Automatic
Manual Climate control switch on dash feels wobbly and is not switching back to the ac when moved to the heater. Stuck on heat. Before it was stuck on ac but turning it off and then back on again. Along with moving the lever from hot to cold finally worked. not sure if it is the temp control lever or the selector switch eg; heater or ac, vents etc. But i think the problem is with the hot to cold lever because the knob/lever is wobbly.
Also there is a clicking noise under dash when the blower is on
Mar 16, 2010 at 2:35 AM
