1993 Mazda MX6
Engine Mechanical problem
1993 Mazda MX6 6 cyl Front Wheel Drive Manual 96,000 miles
i did a engine swap from a 94 mazda mx-6 to a 93 mx-6 both enginges were running before the swap now I got the 94 engine in my 93 mx-6 it wont run the fuel pump comes on after you turn the engine and starts for a sec but shuts right back off if you put gas in the throttle body it runs but it doesnt stay running unless you put a batery charger on it an turn it on (engine start 200 amps) I replaced the alternator, the fuel pump, fuel pressure regulator, and I even addeed extra ground from the body to the motor it still wont start, there is a few vacuum hoses off but what can I do to get this car runnning?
December 2, 2009.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
