How to replace the water pump
MIZZEZBURNZ
  • 1998 MAZDA MPV
  • 6 CYL
  • 4WD
  • 130,000 MILES
My van started overheating and the battery went dead which is probably 2 seperate issues but need to fix the overheating first. It overheated, I checked cooling levels, seen small drip. Checked hoses, no leak. Radiator is new, thermostat is new. (New is 4 months old) when we finally were able to determine leak it appeared to be coming out of engine. At bottom where I would guess the water pump is. Does this sound like water pump and can I find out without having to pay a mechanic because Im broke. Also if you could give me a good idea on how to chane the water pump on this engine becasue it is foreign to me. Any help please. Thank you
Wednesday, August 4th, 2010 AT 4:51 PM
REMOVAL / INSTALLATION
Disconnect the negative battery cable.
Turn the crankshaft so that the No.1 cylinder is at TDC of compression.
Drain the engine coolant.
Remove the timing belt.
https://www.2carpros.com/forum/automotive_pictures/12900_w1_10.jpg
Remove in the order indicated in the table.
Install in the reverse order of removal.
Start the engine and inspect for coolant leakage.
Thursday, August 5th, 2010 AT 5:33 AM
RONH2009
  • 1996 MAZDA MPV
  • 6 CYL
  • 210,000 MILES
I changed the water pump on my mpv and now my van wont start what could have happend
Monday, August 19th, 2019 AT 7:06 PM (Merged)
  • 31,938 POSTS
Hi there,
Just start with re checking any electrical connections that you you undid, and get a scan done as well, it should not be very much.
Mark (mhpautos)
RONH2009
Ok I will check. Also I just found out that it call for the timing belt to be removed wich I did not know at the time why would I have to do this if it has nothing to do with the pump if so could it be out of time
  • 31,938 POSTS
Hi there,
I don't have access to the data base just now, is this a cam belt driven pump? If so the valve timing may be out.
Mark (mhpautos)
