Will not start
BGZAMBONI
  • 1999 MAZDA MILLENIA
  • 6 CYL
  • FWD
  • 130,000 MILES
Car will turn over but will not start, has between 1/4 and 1/2 tank of gas. Have been putting fuel additive in on every fill up. Not sure where to start on fixing problem.
Sunday, January 3rd, 2010 AT 11:40 AM
Cranks and will not start.
Get a helper disconnect a spark plug wire or two and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Sunday, January 3rd, 2010 AT 10:25 PM
RHWALTER
  • 1998 MAZDA MILLENIA
  • 6 CYL
  • FWD
  • 65,000 MILES
Had no power to start or lights and accessories. No power to anything at all.
Replaced battery and still nothing. What else could it be?
Saturday, August 18th, 2018 AT 9:27 PM (Merged)
Inspect and test all the fusible links
2CP-ARCHIVES
  • 4,540 POSTS
  • 30,000 MILES
Mazda millenia does not start. If u give it a hard crank it shows signs of starting but it doesn't. What could be the problem?
HMAC300
  • 48,601 POSTS
Scan for codes and check fuel pressure first.
KENNY718
  • 6 CYL
  • 136,000 MILES
Having problem with starting my car and enegine light is on
Saturday, August 18th, 2018 AT 9:28 PM (Merged)
KHLOW2008
  • 41,814 POSTS
Hi kenny718,
Get a scan done to find out what is wrong.
SARAHMATT0808
  • 1995 MAZDA MILLENIA
Noises problem
1995 Mazda Millenia 6 cyl Automatic 160000 miles
When I first start my car it makes this loud clapping sound around the left side of the engine, after I drive the car it goes away or maybe not as loud to where I can here it. It seems as though it only does it when it is cold cranking up. What do u think the problem could be and should I be concerned?
BILLYMAC
  • 2,204 POSTS
Hi sarah and matt. Well this sounds like if you only hear it when you are cranking the engine, that it almost has to be a starter or flywheel prob, as far as concern yes it should be checked. Could be the diff of a little money or a lot. Good luck billymac
