1993 Mazda b2600 Repair Question
Asked on September 22, 2010
1993 Mazda b2600 clutch wont shift, sound of metal clank
Transmission problem
1993 Mazda b2600 4 cyl Four Wheel Drive Manual
I have a 93 Mazda B2600i, today my truck stalled out at a light and wouldn't re-start, after moving it to a safe spot it re-started. later in the day, i heard a clunking sound and then my clutch stopped shifting, the pettle did depress and release, but the shifter wouldn't budge untill the engine was shut off, then it shifted, I went through each gear and each moved the truck, but I couldn't shift through the gears without shutting the engine off. I drove the truck home in 3rd gear, i did hear a clunking noise when it first started out. I have replaced the Master Cylinder twice before but no other parts to the clutch have been replaced, What could the problem be, the clutch it's self, the throw out bearing, or the release cylinder, could you please assist me, thank you.
